  1. trying to burn mulitpe mpegs with spruce.
    demuxed em all first and then added them to the project.
    and also did the little resolution trick and changed it back before complie.
    but after i burn it and put it in the dvd player, it tries to show with 720x480 resolution. so the 480x480 of the svcd shows up but the rest of it shows up black. so like 1/3 of right part of the scren is just black. anyone run into this problem or know how to fix ??
    May 2001
    Don't you change it back after you compile? Otherwise, Spruceup will compile the way you don't want it.
  3. "After you added the m2v files you save the project and close it. Then you change back the headers in the SVCD MPEG files"
    thats what i did. and it gave me that problem ;/
    anyone got it to wrok with spruce or any other proggy.
    would be willing to try anyothers that would do this too.
