hi guys, i have the tcf screener of super troopers, and when i play the .mpg off my hard drive the file is fine. No sync problems at all. then i take the same file burn it to a cd-r at 10x. put it in my DVD player and the everything is fine, but 10-15 minutes into the movie the Audio is not in sync by like 2-4 seconds.
what was the cause of this problem? is it because i burned it at a wrong speed? all advice is appreciated.
and i read the HOW TO's, but i wanted to see if any of you had any other ideas of what to do. man to tell u the truth i really dont understand the guide that well. pls all help is appreciated.
one of my friends said to multiplex it in tmpeg, but he is a noobie at this too, soi dont know if it would work. what do u guys think?
You do not say if you are running the mpg on a NTSC (USA) or PAL system (Europe)...the problem is probably due to the speed that the DVD player is playing the Video...this may well be different to the Audio speed which is not effected by the type of DVD player you are using...if you right click on the mpg and select properties look for the frame rate...generally 23.976 is NTSC and 25 is PAL...it gets complicated after this because you will need to convert the mpg AND audio to the correct setting for your DVD player...best read the guides!!!
How to solve out of sync ?
By Benjy in forum Video ConversionReplies: 8Last Post: 14th Jun 2011, 07:54 -
Audio Sync Problems
By Blue_3 in forum AudioReplies: 5Last Post: 10th Apr 2008, 19:17 -
USING Nero TO SOLVE ALL BURNING PROBLEMS?
By guitarparth in forum Newbie / General discussionsReplies: 8Last Post: 16th Nov 2007, 19:18 -
Audio sync problems
By alvinboobar in forum Video ConversionReplies: 1Last Post: 10th Jul 2007, 07:22 -
Audio sync problems (again!!!)
By MadMaz in forum Newbie / General discussionsReplies: 10Last Post: 30th May 2007, 21:42
