Hello all,
How can one create manual chapters to VCD/SVCD?
All assistance is highly appreciated.
Personally, I use VCDEasy. Load your MPGs, go to "Chapters", and "Create a chapter at".
Pals,
You probably missed my question.
I know how to burn chapters, my question was how to manually create chapters to a video who don't include chapters in its source, like a movie captured from a tuner.
Take care -
What kind of chapters are you looking for? True chapters are just entrypoints imaged into the VCD/SVCD disc. With these you just push the >> button on your remote or use a numeric entry to jump to specific points in the video. These you do as my original post indicates. If you mean menu type chapters where you select the chapter from an on-screen menu, the easiest way is using Ulead DVDMovieFactory. They have a free trial at http://www.ulead.com/dmf/trial.htm. But the $45.00 is well spent considering the simplicity of use.
Hey Digifreak,
I'm capturing with MoveFactory with scene split set but when I scan for scenes after it doesn't find any. Just the one single clip. It says it can detect scenes based on date. What is the trick ? I'm capturing from a DV cam with firewire connect. The manual has little about this.
Create Chapters with Handbrake
By kinghlg in forum Video ConversionReplies: 0Last Post: 30th Dec 2009, 20:40 -
DVDAuthor can't create chapters?
By Erasmus in forum Authoring (DVD)Replies: 2Last Post: 6th Apr 2009, 12:03 -
How to create chapters for an MKV playable on QT Pro
By VidHunter in forum MacReplies: 0Last Post: 18th Jan 2009, 23:34 -
Final Cut Express 4 can I create chapters for a DVD I create
By Jabroni4872 in forum MacReplies: 1Last Post: 18th May 2008, 11:36 -
Use text file to create chapters in DLP
By milway in forum Authoring (DVD)Replies: 4Last Post: 15th May 2008, 20:18
