i have been downloading dvd backups from server sites for a while. they come in files like RAR/PAR. I have WinRar and SmartRAR...i wanna kno how to burn these files onto a cd-r and be able to watch them on my X-BOX. Can some one please help me, thanx![]()
...Pllllllleeeeeeze, I'm sure you haven't so much as read one thing at this site. Don't expect a response until you done your homework and used the "Search" button on this site! This post is the most vague I've seen yet.
KillerB,
You don't say how far you've got already, so I'll start at the top. Once you have downloaded all of the Rar files click on the on the first file "Whatever.rar" to load it into WinRar and then selct extract to extract them into 1 or 2 files.
Once you've done this you need a program to burn VCD's, personally I'd recommend VCDeasy as its real straight forward to use, and you can get it from this site.
If you have extracted an .mpg file earlier on then just drag it into the main box, pick a blank CD-r in the drive, and hit the Go button. If you extracted .bin & .cue file then go to the tools section of VCDeasy, select the CDdao button and then input your .cue file in the "burn a cue file" section and hit the Burn button.
Hope this helps, for a more in depth explanation check the guides section
Yep, read the "how-to" guides. A little time invested in reading will save much more time in the future.
As Churchill famously predicted when Chamberlain returned from Munich proclaiming peace in his time: "You were given the choice between war and dishonor. You chose dishonor, and you will have war." -
You might need a mod chip. Do a yahoo search for
xbox mod chipAs Churchill famously predicted when Chamberlain returned from Munich proclaiming peace in his time: "You were given the choice between war and dishonor. You chose dishonor, and you will have war." -
yea ur rite it needs a modchip, do u kno where i can get a real real cheap dvd player/ vcd player? if do tell me
DVDs burn fine, but Audio CDs only burn 1st half of songs right...
By Xenogear900 in forum Authoring (VCD/SVCD)Replies: 7Last Post: 28th Jan 2010, 05:26 -
DVD Rom can burn DVDs but won't recognize burnt DVDs.
By soonie in forum DVD RippingReplies: 0Last Post: 23rd Aug 2009, 17:03 -
Question why these X8 DVDs only burn at X4
By jimdagys in forum MediaReplies: 4Last Post: 17th Jul 2009, 14:59 -
trying to burn dvds
By steelercanes83 in forum Authoring (DVD)Replies: 1Last Post: 15th Oct 2007, 21:59 -
Software to burn HD-DVDs
By indie1982 in forum DVD RippingReplies: 4Last Post: 8th Sep 2007, 14:36
