  1. Okay, the first problem I'm having is when I get a bin and cue file thats SVCD. When I burn it then I try to play it in the vcd player it doesnt play. I always either have to go the second chapter first then come back to the first chapter. It just wont start up when I hit play. Is there any kind of way to get it to start just by hittin play. Now when I use my PowerDvd on the computer it works fine by just hittin play, but it wont work in my Apex 1500. When I hit play it will look like it tries to start but then it just comes back to the DVD Logo Screen.
    Now it works when I make the .bin file to mpeg with VCDGear, but lately when I have gotten an SVCD .bin file and turn it to mpeg and try to burn it with Nero it keeps saying that I need to insert a disk big enough. I know I have an 80 minute disc in but it never works right. I also have it on overburn but Nero just wont burn it. I dont know whats going on. When I look at the bar at the bottom the bar is slightly, and I mean just slightly, over the 80min mark. I dont know what else to do with it. I have also tried using VCD Easy, but its having the same problem. The file is too big. The VCD's work fine... but the svcd's just dont work right. They have been giving me problems that I didnt used to get before. Anybody got any ideas.
  2. Try pressing the number 1 on the handset to start
    "lately when I have gotten an SVCD .bin file and turn it to mpeg and try to burn it with Nero " - Are you saying you are ripping the MPG out of the bin and then trying to reburn as a SVCD? Or are you just burning the MPG file as a data CD? You must try and burn as a svcd/vcd otherwise the mpg is unlikely to fit on a CD.
    Why not just burn the bin/cue in the first place using fireburner?
  3. I said that at the top. I said that when I burn the .bin file that it doesnt play right in the dvd player. When I hit play it doesnt start... it will only play on pc... am I doing something wrong.
  4. Are you actually burning the .bin file with nero? It sounds like you are just dragging the .bin into the project..? A bin/cue is a disk image so you need to burn the image.
    In nero, to burn bin/cue's you need to start nero - (assuming you have disabled the wizard) hit 'new compilation' - goto toolbar - select 'file/burn image' - browse to and select the .CUE file - hit 'write cd'
    another important tip is to open the .cue file in a text editor and remove any driveletter references in the first line. All that should be on that first line is the name of the .bin file (assuming that you have the .bin and the .cue in the same folder)
    Hope that helps.
