I usually use tmpge, but since it takes forever for SVcds with vbr I'm gonna try the cce demo. My question is can it use the same source files as tsunami, (the d2av and wav file) or is there a seperate method that must be used ie mp2 audio or avi video.
thanks.
Bruceleroy,
If your gonna use CCE, I would recommend downloading and using DVD2SVCD, it will set CCE up for you and gives great results.
Otherwise you'll need to use a progam like FitCD to resize the .d2v file and re-label it to an .avi file. Then a separate program like HeadAc3e to convert the audio to mp2, and finally you could use TMPGenc to multiplex the audio and video together into a SVCD compliant stream.
Hope this helps -
I've been using CCE with the .d2v usnig Avisynth. I process the audio separately due to audio problems with CCE. Go here to learn how...
http://forum.vcdhelp.com/userguides/78221.php
Question re settings in CCE Basic
By eclipse95 in forum Video ConversionReplies: 4Last Post: 6th May 2009, 16:17 -
CCE Gui Question.
By Maikeru-sama in forum ProgrammingReplies: 1Last Post: 11th Jun 2008, 19:42 -
CCE, AviSynth and MP4 Question
By Maikeru-sama in forum Video ConversionReplies: 5Last Post: 31st Mar 2008, 11:19 -
MKV, CCE and AviSynth Question
By Maikeru-sama in forum Video ConversionReplies: 10Last Post: 14th Jan 2008, 16:35 -
AC3 and CCE Question
By Maikeru-sama in forum Video ConversionReplies: 6Last Post: 9th Jan 2008, 17:18
