What is the preferred format for DV-AVI files: type 1 or type 2? Also, I have a utility from Ulead that will convert back and forth between them, as some software like Windows Movie Maker requires type 2 and Ulead DVD Movie Factory requires type 1. Will this conversion reduce quality or can I convert back and forth freely and keep the original DV file quality?
Really the "preferred format" is just what the application expects or requires. If you are using Premiere, the DV needs to be in Type 2. ULEAD products use Type 1 as standard. Both formats have the audio interleaved with the video, Type 2 adds a separate audio track to the file.
I can't vouch for the specific converter you are using, but you should be able to go back and forth with no degradation to the file. -
The following program lets you chose between capturing in type 1 or type 2 DV avi:
http://www.carr-engineering.com/dvio.htm
Convert DV type 2 to type 1? Or is there an app that will correct sync?
By Colmino in forum Newbie / General discussionsReplies: 7Last Post: 20th Dec 2022, 21:24 -
How to convert a trp type file to Mpeg2 type?
By Jemes-bs in forum Video ConversionReplies: 2Last Post: 13th Oct 2010, 15:59 -
type 1 or type 2 capture-newbie
By sar in forum Capturing and VCRReplies: 6Last Post: 28th Jul 2008, 18:22 -
DV AVI Type 2 -> Type 1 converter?
By alx3d in forum EditingReplies: 3Last Post: 29th Dec 2007, 20:16 -
Convert Type 2 DV to Type 1 (DVdate?)
By nlec in forum Video ConversionReplies: 30Last Post: 30th May 2007, 13:52
