Hy
i recently brought a pioneer 535 region 2 its a great player but i just borrowed a vcd of my mate blair witch and it plays teh dvd but jsut in black and white is this becasue its a ntsc vcd???
and is there any form of way of making it a all regions player?
I have the same player (but R4), and have played PAL and NTSC VCD's no problem (and in glorious - if you can say that about NTSC - coloUr), however, my other DVD player (Hiteker AD-600A), which is connected to a much older TV will only play NTSC's in B&W (thankfully you can force the output of that player to PAL).
In direct answer to your question, yes it probably is a NTSC VCD, and your TV just can't cope with it!
Anyone, shoot me down if I'm wrong. -
You should find a switch on the back panel of your dvd player to force the output signal to PAL.
cya
thats right m8, i have the dv-530 pioneer look at the back of the dvd player and see if there is a switch that u can use for pal ntsc or auto, i live in the uk and leave it on pal and it plays them all fine vcd, cdr cdrw etc, ntsc tends to play them back in black and white depending on the source, and auto is a bit dodgy as sometimes it cant make up its mind wether to play in colour or black and white but since switching to pal no problem, hope this helps
stu252 -
I have the same problem, only a different player, the pioneer DV-340. That one does not have a switch at the back, anyone got a suggestion for this one?
Thx up front,
Suzanne
LG LDV-535 Remote control Codes
By Lukas2k in forum DVD & Blu-ray PlayersReplies: 0Last Post: 4th Oct 2011, 21:32 -
Pioneer DVR
By vcd4me in forum DVD & Blu-ray RecordersReplies: 20Last Post: 25th May 2011, 01:33 -
Pioneer DVR-112 seems to stop my Pioneer DVR-115 from being recognized
By Thommo1978 in forum DVD & Blu-ray WritersReplies: 9Last Post: 3rd Feb 2008, 07:02 -
Pioneer dv-400k
By markarcade1 in forum Newbie / General discussionsReplies: 2Last Post: 14th Jan 2008, 15:44 -
pioneer dv400vk
By suomiaussie in forum DVD & Blu-ray PlayersReplies: 4Last Post: 9th Sep 2007, 09:42
