  1. There's a CDR indentifying program called "CDR Ident" that tells you the CDR manufacturer information and stuff like that - but is there a similar program for DVDR and RW media?
    advdinfo
    http://forum.firmware-flash.com/viewtopic.php?p=9479#9479
    haven't tested it so it may suck.
  3. It works good for me. Make sure you have WINASPI32.DLL in the same directory as the Utility.
    RG
  4. The program seems to be great but it just does not work.
    I even installed the new 4.70 ASPI drivers and copied advdinfo.exe into those folders (1 C:/Win/system32/ 2- C:/Program Files/Nero/ )- nothing. Both locations tested. Still nothing.
    It just gives an error on startup "Could not create device list" Any suggestions?
