I am try to make an XVCD but I don't want to used 352x240 res as the final resolution, so what I did is add the following line in the avisynth script
ReduceBy2
Addborder(176,120, 176,120)
(the video 352x480 doesn't look as good when it been stretch to fit on a 50 inch tv)
So my question is how many bit does it take to encoded the border around the video?
Thanks in advance
If you pay attention to the macroblock boundaries, almost no bits are wasted to the borders. Well it depends on the encoder too.
ReduceBy2
Addborder(176,112, 176,128) -
If I use CCE to as my encoder do I loose any bits to the borders with the new changes you have suggested.
ReduceBy2
If your source is 704x480 (I guess it is, because you use ReduceBy2), and you use ccesp 2.50, resize to a multiple of 16 minus 1 pixel top and bottom.
Crop(0,2,704,476)
ReduceBy2
AddBorders(176,113,176,129)
If you use ccesp 2.6x (due to different motion compensation)
Crop(0,4,704,472)
ReduceBy2
AddBorders(176,114,176,130)
Calculated by FitCD.
10-bit encode capable tools?
By rapunzel in forum Video ConversionReplies: 0Last Post: 25th Feb 2012, 22:54 -
how to encode aac 5.1 to ac3 on the fly in 64-bit windows 7
By MR 3 in forum AudioReplies: 3Last Post: 4th Apr 2010, 18:47 -
I have a 64bit system, to encode files do i need 64 bit codecs?
By shadowofanubis6 in forum Newbie / General discussionsReplies: 5Last Post: 1st Mar 2010, 11:24 -
Need a bit help with DVD authoring (doing audio change without re-encode)
By loa0305 in forum Authoring (DVD)Replies: 4Last Post: 26th Mar 2008, 17:21 -
little bit of pixels after encode
By StoneColdWhat in forum Video ConversionReplies: 21Last Post: 28th Jun 2007, 17:47
