Today I purchased a Pioneer DVR-AO4 DVDR/RW Writer, and I cant get it work in my system. It just cant read any data off any media thats in the drive.
Control Panel \System\ Device manager \ Hardware the drive is recognised and installed.
BIOS recognises it at bootup. Works 100% ok in DOS
I tried a new XP installation booting from the Pioneer DVR-AO4 DVDR/RW
Everything went fine, installation finished then rebooted after the install
and EXACT SAME THING happened. Wont read from the drive. (Obviously the problem is in Windows XP)
Tried it as a master and also a slave, removed EVERYTHING from the PCI slots.
Still the same.
I took it back to where I purchased the drive and they tried it in another system with same motherboard, and it worked perfectly
The shop wants a 10% restocking fee for the return of this drive. (I paid
$850 here in Australia) so I would dearly love to get this going.
Any suggestions
Did you try disabling DMA on the drive. I too have the A04 on WinXP and Nero wouldn't burn to it 'til I made the drive have PIO access.
Go to your Device Manager in XP and choose the Primary or Secondary IDE channel. Choose Properties -> Advanced Settings and make the transfer mode "PIO Only" (or something like that).
Good Luck. -
OK tried altering the drive settings in BIOS to PIO Mode 1,2,3,4, & 5 made no difference.
Also changed the setting manually in Control Panel \ System \ Device Manager Secondary IDE port to PIO mode.
This made a difference, it could read the volume label on the disk but still couldnt see any files. Also after doing this the sytem booted at a normal speed instead of taking 5 minutes to get to the desktop.
Put the AO4 in a ME system and worked flawlessly. Unfortunately I am going to be working with large video files so ME isnt a solution for me.
Thanks for your words of advice -
Hello!
Pioneer DVR-AO4 ,
The first time i burned a dvd-r with Nero i could burn in 2x but now i can not select 2x only 1x for dvd burning. Nothing seems to help.
Could the problem be in Nero or is it the DVD burner?
Has anyone else had this problem?
Is there any else program besides Nero that display burn speed for DVD? -
Yeah I get that same problem too. Well it's actually not a problem. NERO just dectects that your cheap DVD-R media is only 1x compatible. Forcing 2x (don't know how you can) will destroy the disc......dunno about drive.
NERO has the tendoncy to detect all the writing compatiblility speeds that the disc physically can sustain. So don't expect DVD burning to display 2x unless your media says 2x compatible on there. Ya can't assume either. You'll know when you have 2x media. Take a look at the price tag.... -
Hello.
Can you select 2x In nero with no disc in the drive?
I could do this in the beginning when the drive was new, but not anymore.
I have tried with several computers (with Nero) but I can only choose 1x.
Doesn't seem like it's a medium problem, In my eyes it looks like its something wrong with the drive... or..........?
Pioneer DVR video outputs not working - possible to fix? other options?
By JimmyMcV in forum DVD & Blu-ray RecordersReplies: 2Last Post: 10th May 2010, 23:59 -
Pioneer DVR-520h or DVR-220 or DVR-225 replacement DVD-RW drive
By psymaster in forum Newbie / General discussionsReplies: 1Last Post: 31st Oct 2009, 19:48 -
By psymaster in forum Latest Video NewsReplies: 1Last Post: 31st Oct 2009, 17:26 -
Replace Pioneer DVR-104 with DVR-115D? EIDE cable the same? Other questions
By Goldenvoice in forum DVD & Blu-ray WritersReplies: 1Last Post: 13th May 2008, 07:20 -
Pioneer DVR-112 seems to stop my Pioneer DVR-115 from being recognized
By Thommo1978 in forum DVD & Blu-ray WritersReplies: 9Last Post: 3rd Feb 2008, 06:02
