I am trying to rip an 84 minutes long PAL movie, using DVDx and TMPGEnc. Everything seems in order. Both programs report 100% done, and the resulting MPEG is 84 minutes long. However, it ends a few minutes too early in the movie.
Any clues?
DVDx 2.0 - TMPGEnc 2.56
VCDEasy 1.1.1 - VCDImager 0.7.12 - Cdrdao 1.1.5 -
Can you please tell me how you were able to make DVDx 2.0 and TMPGenc to work properly?
How did you install the VideoServerPlugin?
I tried following this: http://www.doom9.org/mpg/dvdx-tmpg.htm
but I can't find the CM-avisynth.prm in the files.
When I click on DVDx to encode it gives a donation warning. When I pass the additions test it somehow "works" but when I start TMPGenc and browse for the output file of DVDx, it crashes.
I hope we can help each other out.+ Basta Ikaw Lord -
I don't quite remember, but I know I didn't have any problems.
IIRC, I just unzipped the videoserver archive in the dvdx directory and it worked. Please note, I am not using AVIsynth, but AVI wrapper. There is no CM-avisynth.prm file, but a cm-videoserver.prm.
Output settings: Premiere plugin encoder: Video Server
Plug settings: Frame server: Server mode: AVI wrapper
Plug settings: Frame server: WRAPPER Server settings: Filename: C:\My Documents\DVDx.avi
Plug settings: Frame server: WRAPPER Server settings: Normal audio export
In TMPGEnc, open C:\My Documents\DVDx.avi.
Good luck!DVDx 2.0 - TMPGEnc 2.56
Need a DVD 30 minutes after the game?
By Telemov in forum Newbie / General discussionsReplies: 56Last Post: 15th Feb 2012, 21:39 -
Only convert the first 10 minutes or so ...
By GMUET in forum ffmpegX general discussionReplies: 4Last Post: 8th Jun 2011, 14:13 -
How to shut down harddrives after 20 minutes
By mysts in forum ComputerReplies: 2Last Post: 20th Jan 2010, 02:19 -
FitCD thinks 43 minute video is 2 minutes long - ditto TMPGEnc
By natrap in forum Video ConversionReplies: 3Last Post: 2nd Aug 2009, 21:02 -
latest few minutes missing on DVD
By coxy in forum Newbie / General discussionsReplies: 8Last Post: 5th Jul 2007, 02:47
