Hi freind,
I convereted a DVD to VCD format as follows.
Using SmartRipper i ripped the DVD
Using DVD2AVI i created a project file
using Voblist created a WAV file
and using Tempgnc i got the output in mpeg format and finaly using Roxio video pack i got into VCD,
But the audio quality is very good, but Video quality is okay by 70% only,
How can i get the same video quality of DVD itself, Is it possible for me to get it???? should i make any changes in the softwares i used,
Could anyone help me???
Thanks and Regards
What sort of settings did you use in tmpgenc? Was it a standard template?
You can NOT get "DVD quality" video in a VCD. Consider that you are converting what is likely a 720x480 (or 720x576) MPEG-2 file with a bitrate of up to 9,800 kbit/sec VBR all the way down to 352x240 (or 352x288) MPEG-1 with a bitrate of only 1,150 kbit/sec CBR. 9,800 vs. 1,150; around one-eighth the bitrate, no way it can be as good.As Churchill famously predicted when Chamberlain returned from Munich proclaiming peace in his time: "You were given the choice between war and dishonor. You chose dishonor, and you will have war."
BD / DVD Digital Video Quality as compared to Uncompressed RAW video.
By Bonie81 in forum Newbie / General discussionsReplies: 4Last Post: 5th Dec 2010, 08:11 -
best audio video quality of youtube poor quality and not hq flv videos.
By nusratjaveid in forum Video ConversionReplies: 3Last Post: 20th Jun 2010, 19:23 -
Convert .avi movie files to vcd or dvd without loosing picture quality
By akakiami in forum Video ConversionReplies: 8Last Post: 8th May 2010, 17:01 -
Video Quality on DVD
By Genison in forum DVD RippingReplies: 6Last Post: 9th Aug 2009, 20:58 -
Low quality video on high resolution screen, improve video quality?
By Nitrius in forum Software PlayingReplies: 4Last Post: 29th Dec 2008, 13:38
