i was getting speed up to 6x and 8x ripping with smartripper 2.41 and now im only get 1.9x on both of my dvds (dvd-rom and Ao3) i dont know what happened but its very slow and also the led light on both dvd drives kept on blinking.... anybody know what happens?![]()
ok nevermind fixs my own problems ....now my ripping speed even better
now im ripping at 13x..ripping a 4.3+gb under 5 mins but i though it was just the dvd so i place another movie this one 4.4 gb and ripping it at 14x in 4 1/2 mins
But your solution should be intriguing to the rest of us. Why don't you shead some light? How did you get from 6-8X to 13-14X?
ok i have two dvd drives one is pioneer ao3 and toshiba dvd-rom. my toshiba is the secondary master and ao3 is slave....make sure you use ata 80 to 100(to get the best performent) in my cases i was ripping dvd at 6x to 8x for months and was very happy then the other day it just rip real slow (1.9x).... i found out my dma has been switch to "pio only" mode ..so i went in and changed that reboot my pc but its still slow (3x) so i un-install the secondary ide channel then reboot let windows reinstall everything afterward i test it out...work flawlessly..im still ripping at 13x+ on both karaoke and dvd movies...oh by the way my dvd-rom is 16x and ao3 i believes its at 8x speed ( i dont use my ao3 to rip at all) i think...anyways have fun testingOriginally Posted by SLK001
Any Vancouver Olympic observations? 1080i 29.97 sure helps here vs 25.
By edDV in forum Newbie / General discussionsReplies: 6Last Post: 28th Feb 2010, 18:57 -
Really need some serious helps with DVD Shrink!!!
By coxanhvn in forum Newbie / General discussionsReplies: 13Last Post: 4th Jul 2009, 06:31 -
I killed my GSA-H22N LG driver!!! Please, somebody helps!!
By Bruxo in forum DVD & Blu-ray WritersReplies: 7Last Post: 13th Oct 2007, 16:22 -
Sorenson Sq 4.5 Crashes - My Firstborn for anyone who helps!
By CLE in forum Video ConversionReplies: 3Last Post: 29th Aug 2007, 08:23 -
Helps with Magnavox dv200mw8
By mairel in forum DVD & Blu-ray PlayersReplies: 0Last Post: 7th Jul 2007, 10:36
