Its like this, i have a video and i want it to make it brighter. I open VirtualDub then Video/Filters/Add/Brightness and Contrast then i set the settings then i press ok, now it brings me back to the video screen.
I press play two sceens showed up, one is brighter than the other one, after it finishes what do i do next? Or i got this whole thing wrong?
Thanks![]()
goto file....save avi
be sure to give it some compression, otherwise it will chew up your hard drive fast -
GTR,
The Second video is showing how the output of the video will be whether you decide to save it again , which isn't recommended if you have segmented files, or how it is going to look when the video is frameserved to another application, most likely an encoder. Video on the left is the original and the one on the right is the output after the filter has been applied; now you can either save the output file and there your video will have the new effects you've added via the filters, or you can frameserve the video to another application that application will only see the video as it is shown on the right.
What do you want to do with the video after you've brightened it up.
I.E. Say you have a single DivX file and you want to brighten it up, open the video (full processing mode) use the brightness filter and adjust it to your tastes, now you can just save the AVI as another single DivX file only now the new DivX file will have the brightness adjusted.
I.E. You can also have the filter applied to the video without saving it, where you can just frameserve the video to another application thereby foregoing the need to save another AVI file. -
Thanks everything is cleared up now. I have an mpg file if i save it as avi so i have to convert it back to mpg right. Im making a vcd.
Virtualdub and Filter Related problem
By frmys in forum EditingReplies: 26Last Post: 27th Jan 2011, 13:16 -
VirtualDub: Layer Filter
By creamcone in forum EditingReplies: 6Last Post: 26th Dec 2010, 12:27 -
VirtualDub filter
By nic3 in forum EditingReplies: 6Last Post: 30th Sep 2010, 10:48 -
VirtualDub Filter Blending
By sambat in forum EditingReplies: 4Last Post: 6th Sep 2009, 15:07 -
VirtualDub Filter During Capture?
By CosmicOutburst in forum Newbie / General discussionsReplies: 4Last Post: 26th Nov 2007, 19:48
