I was able to convert an mpeg2 into mpeg1 yesterday using TMPG, and I try to bring up the same file and now it gives me an error saying that it can't open the file or it's unsupported. Anyone have any clue what's wrong?
If nothing else, I can always serve as a bad example
I found out what it was- I had accidently installed the newest version of TMPG, so I installed an older version and it works now. Thanks anyway ^^
If nothing else, I can always serve as a bad example -
well u can always download TMPGenc from other "sources" and then u can convert with the newest version.
hehehehe hope u know wot i mean :P
Looking for a BD Authoring software that dont re-encode MPEG2 Files
By faramith in forum Authoring (Blu-ray)Replies: 11Last Post: 14th Dec 2011, 04:39 -
Need To Batch Encode 78 MPEG2 Files
By hech54 in forum Video ConversionReplies: 7Last Post: 31st Dec 2010, 07:10 -
DVD FLICK Bug? 1.0.3.6 version won't encode mpeg2 files properly...??
By bahjan in forum Authoring (DVD)Replies: 0Last Post: 21st Jan 2010, 06:40 -
WMP11 won't play mpeg2 files after installing Catalyst driver
By jrlouie in forum Software PlayingReplies: 0Last Post: 8th Dec 2009, 21:08 -
Mkv to divx with ac3, ffMpegX will not encode anymore.
By biggyk in forum ffmpegX general discussionReplies: 15Last Post: 31st Jan 2009, 15:48
