Hello,
I'm a long time reader, first time poster. I'm not that advanced with ripping DVD's, but I consider myself knowledgable. Currently I have ripped the VOB files from my Shrek DVD to my hard drive using smart ripper, and have frameserved it with DVD2AVI. I open the .d2v in TMPEG and I select my settings to encode it to SVCD. When I go to preview, to see what my output will look like, I get lines running across the frames. It does not happen at every frame, but seems to occur very often. I have noticed this with other DVDs I have tried to rip, and I can not find anything which mentions how to fix this. If someone could please recommend to me a way to fix the lines running across the frames I would be grateful. Thanks. It seems to occur when there is some sort of action, not when the characters are just sitting around.
Catchy phrase goes here ---->" "
something like this?
http://forum.vcdhelp.com/viewtopic.php?t=91495&start=0&postdays=0&postorder=asc&highlight=dvd svcd using dvd2avi frameserving tmpgenc -
this is what you gotta look for in DVD2AVI
Frame Rate = 25.000 fps: your source is PAL and you can skip the following step.
Frame Rate = 29.970 fps: Let the preview run for a couple of minutes, then take a look at the Video Type: If it's FILM at a percentage higher or equal to 95% you can activate Forced FILM as shown below. Otherwise you will have to perform IVTC(InVerse TeleCine).
in DVD2AVI
for Inverse Telecine - click on Video -> Field Operation -> None
for Film 95% and higher - click on Video -> Field Operation -> Forced Film
then you gotta set the Inverse Telecine in TMPGenc
but all I see is this
TMPGenc
Setting -> Advanced -> [x] Inverse Telecine (Convert to 24fps: Non-Interlace source)
hope someone else can elaborate on this -
Thank CryptKeeper, that was exactly what I was looking for
WinX DVD Ripper Platinum Ripping at Wrong Bitrate
By wperry1 in forum DVD RippingReplies: 14Last Post: 15th May 2015, 14:05 -
Ripping a Region 2 DVD on a Mac Book Pro with Mac The Ripper
By Jess021 in forum MacReplies: 7Last Post: 17th Nov 2011, 06:04 -
Menus not shown in DVD Decrypter or Smart Ripper
By EmpireStrikesBack198 in forum DVD RippingReplies: 2Last Post: 11th Jun 2008, 17:48 -
ripping and shrinking with mac the ripper
By 91rtstealth in forum MacReplies: 17Last Post: 19th Mar 2008, 14:23 -
Smart ripper help
By holland11 in forum Authoring (DVD)Replies: 4Last Post: 13th May 2007, 02:15
