Hey everyone! I'm a NewBie and really need help.
I downloaded a DVDrip of a movie but my DVD does not support those. I'm guessing DVDrip are in a format of MPEG2 (SVCD) right? Well, since my DVD doesn't support SVCD, I did that trick by putting a VCD header on your SVCD to make you DVD player think it's playing a VCD. I used TMPGEnc.
So I pop it in the DVDplayer and it plays fine and the quality is the same.
Then, I downloaded another movie (SVCD) format. I did that same as I did with the first movie. But, when I play it i nthe DVD player, it comes out green blocky screens and it doesn't play properly. But it does play properly on the computer.
Any idea as to what the problem is?
Thanks!
Is it maybe the burning? Maybe something went wrong when I was burning it?
Anyone?
VCD cannot play in PC but can play in DVD player
By avatar123 in forum Authoring (VCD/SVCD)Replies: 28Last Post: 3rd Jan 2011, 17:32 -
my panasonic standalone dvd can't play pal dvds...but can play pal svcd's
By stoico1 in forum Newbie / General discussionsReplies: 0Last Post: 9th Sep 2009, 17:46 -
VCD to DVD (not SVCD)
By noyou in forum SVCD2DVD & VOB2MPGReplies: 20Last Post: 19th May 2009, 17:56 -
Will a DVD player play any files but DVD/VCD and CD audio?
By brassplyer in forum DVD & Blu-ray PlayersReplies: 3Last Post: 24th Sep 2008, 20:32 -
Newbie trying to figure out DVD to SVCD/VCD
By 4194 in forum Newbie / General discussionsReplies: 14Last Post: 26th Aug 2007, 09:34
