i have tried doing the Start / Program Files / Accessories / Volume Control / check the record bullet and see if Line IN is check , and it was.
im getting no sounds when i play my videos at all i tryed the default WinTV2000 And AVIIO [Something like that]
my card is a WinTV FM i think, well its got FM Tuner on it, it doesnt have a sub-name on the box.
i came here to see if the pros could help
Paul
I'm definitely no pro, but the way I fixed mine is when i record, I put the audio plug that goes from the TV Card to the Sound Card into the Mic plug. It's a pain to do every time, but it works. If there is a better way, I'd love to know.
i have loads of mic plugs *lol*
one on the monitor, one on the speaker, one on the back. -
you need to take the audio out and a line in or mic in (both should be in the back) and connect those two.
ok.
your capture card should have a audio out port (i think)
you need to connect that audio out to either a line or mic in port of your sound card. (in the back of your computer)
then the audio will feed out of you capture card and into you sound card. you sound card will play it through your speakers, headphones, whatever (if theyre connected). you should be able to hear audio then, if you cant then youll have to check your software.
is that easier to understand? or did i make it worse?
Do you get sound when you play avi, mpg, wav or mp3 files from other sources than your captures? If yes then we know your speakers are hooked-up ok.
Then check your connections. I dont have that card but lets assume a cable input, composite video in, audio line-in, audio line-out and (possibly a svideo input). The only ones of concern here are to make sure that if your using an external source for input lets say a vcr (composite video in and audio line-in) make sure that the RCA jacks and/or mini plug are connected to the proper video and audio inputs. The audio signal from your VCR should be heard through your speakers clearly even before you start the capture. Next check that the audio line_out from your Capture card is connected to the line-In of your sound card. Next make sure that the line_in "record" (not the play)option is selected (on win98 thats the speaker icon). When you play the file back make sure that the WAVE play option is not muted and that the volume for the wave is up.
If you still have problems try another capture app and report your results in greater detail. -
it all works fine. gll99, hell of a post man ...its posts like that,that help people, im just a dumbf*ck who dont know there wires/in/outs/svideo
"Then check your connections. I dont have that card but lets assume a cable input, composite video in, audio line-in, audio line-out and (possibly a svideo input). The only ones of concern here are to make sure that if your using an external source for input lets say a vcr (composite video in and audio line-in) make sure that the RCA jacks and/or mini plug are connected to the proper video and audio inputs. The audio signal from your VCR should be heard through your speakers clearly even before you start the capture"
me not understand...but i have this S-Video adapter thing i think,its double sided coax:/
all my probelm really is:
sounds fine until i try and play my capture, in this case Childs Play 3,whole movie captured..sound was great while capping, pi??ed off when i played it with no sound..
howeva i did try and cap again today using mic jack[fyreboltx2] instead of line in, it worked the sound was very loud and was awefull but the best i got so far [har-har]...
ATSC tuner card that captures surround sound
By Theophilus in forum Capturing and VCRReplies: 3Last Post: 4th Jan 2011, 07:50 -
no sound in DV captures
By Onceler2 in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 17Last Post: 6th Jan 2010, 13:59 -
what's a good sound card to use for my captures?
By kukuo522 in forum Capturing and VCRReplies: 4Last Post: 3rd Aug 2008, 21:53 -
Best Captures for RF?
By therock003 in forum Capturing and VCRReplies: 10Last Post: 29th Jul 2008, 15:56 -
Screen Captures?
By newsphotog in forum Newbie / General discussionsReplies: 1Last Post: 29th Feb 2008, 16:35
![Send a message via AIM to [R][V][D]](images/misc/im_aim.gif)
