How to convert DVDs to VCD using DVD player DV camcorder and Fire Wire card?
someone needs to read the guide before asking questions that are answered in the guides.
ive never herd of converting dvds to vcds using a dv camera and a firewire card... if there exists a way, then ill admit im stupid.
the closest thing i can think of is, capturing from your dvd player using a capture card. -
Correct me if I'm wrong. Do you mean CAPTURING a dvd movie using your dvd player thru your dv cam because you have a firewire card and your dvd player has no firewire connection? If I am right, your dv cam should have both vide/audio input so that you can connect your dvd player to your dv cam and you can use it as your bridge as if you were directly recording to it.
hey, that makes sense... i got thrown off cuz he said convert
ok ok im stupid!
but how would the quality be? robert, if you try it, then let me know, this is quite interesting. -
Wouldn't the copy protection (fading in and out brightness levels) kick in and ruin your party? This is the same reason why you can not record DVDs to VHS tape.
Yes the macrovision causes the usual problems and in some cases the camcorder will not let you pass the protected material.
It is really a lot easier to just rip the DVD and avoid another conversion step.
Camcorder Video to Several DVDs with menus
By vanillafrozen in forum Newbie / General discussionsReplies: 1Last Post: 9th Oct 2011, 05:12 -
Need codes to convert Australian DVD player into a multi region DVD player
By Seajacb123 in forum DVD & Blu-ray PlayersReplies: 1Last Post: 13th Oct 2010, 02:00 -
Convert Camcorder DV files for Media Player - what format
By davidm_uk in forum Newbie / General discussionsReplies: 3Last Post: 23rd Dec 2009, 09:17 -
How Can I Convert Real Player Video Files To Make Them DVD Player Compatabl
By Lennoxtown in forum Video ConversionReplies: 8Last Post: 17th Oct 2007, 07:05 -
How to convert IFO/ Vob to mpeg (sony DVD camcorder)
By Guthix in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 2Last Post: 23rd May 2007, 19:05
