Hi,
I captured in AVI then opened it up in GoldWave and applied a preset filter to remove hiss.
I then saved the amedned WAV file and run it through TMPEG with my video to create a better sounding VCD.
Fine...
But, all of a sudden, when I apply the filters in ANY sound editor, whether it be GoldWave or CoolEdit or anything else... the sound distorts a little and sounds as if it is slightly under water. A sort of mechanical sound.
I have no idea why this has just happens as everything was working fine.
I have tried different quality settings but after applying the filter the sound still changes instead of just cutting a little of the hiss like it used to.
This is all very bizzare and I wondered if anybody had experienced this before?
Many thanks indeed!
Gray
Results 1 to 1 of 1
Bizzare problem capturing - NEWBIE
By Aarell in forum Newbie / General discussionsReplies: 2Last Post: 17th Jan 2012, 11:38 -
Double Layer Issue That Is Beyond Bizzare..I think I killed the burner
By mrjoelabs in forum DVD RippingReplies: 5Last Post: 1st Sep 2010, 09:49 -
My lcd tv have a problem or this is blue shadow/artefact its a normal thing
By Cristal in forum DVB / IPTVReplies: 5Last Post: 26th Apr 2008, 00:11 -
Hissing Sound in the Background
By Jenny in forum Newbie / General discussionsReplies: 2Last Post: 10th May 2007, 02:04 -
Bizzare iPod Behavior with converted MP4 - help!
By cosgrove in forum Portable VideoReplies: 0Last Post: 4th May 2007, 10:08
