Hi All,
I have run into a peculiar problem. I recently encoded Blade from divx-->svcd. At the beginning of the movie the picture is great and the audio is in sync, but as soon as an action scence is about to begin the A/V becomes out of sync, just by a few seconds but enought to ruin the good scences. As soon as the action is done the A/V returns back to normal and in sync. I was using
CCE 2.5 SP
Multi Pass 4
Max Bitrate 2500 min 1500.
I Used tmpeg/toolame to convert the audio and BBMEG to mux the A/V.
Next i tried using TMPEG on the same file. And as i thought the A/V was in perfect sync, but the video quailty wasn't as good as CCE.
I don't know a lot on how CCE mulipass Works, so maybe some of you pros and explain a little bit on why on complicated scences the A/V becomes out of sync.
Thankyou
Results 1 to 1 of 1
audio sync problem, how to work out progressive audio sync delay
By jolt321 in forum Newbie / General discussionsReplies: 13Last Post: 10th Apr 2012, 21:09 -
MKVvextract stretches extracted audio/Audio not in sync with video
By cgo in forum Video ConversionReplies: 16Last Post: 15th Jan 2012, 17:15 -
How to sync the dubbed audio to make a dual audio .avi
By Scotter in forum AudioReplies: 4Last Post: 24th Dec 2011, 15:17 -
An app to visually sync audio to video similar to Subtitle Edit visual sync
By cinesimon in forum AudioReplies: 3Last Post: 6th Sep 2011, 07:54 -
SOLVED: Audio out of sync or no audio - mkv/h.264 to avi/xvid
By dwoozle in forum Video ConversionReplies: 3Last Post: 2nd Feb 2009, 16:14
