I was woundering how long dose it take to encode an avi file to a vcd if i were useing the TMPGEnc program. Aslo what kind of settings would i use if i want to watch it on my dvd player and what would be a good program to burn the file so i can make it a vcd thanx. 8)
Encoding depends on the size of your original file, the template you select, and the speed of your machine, for starters. To convert, we all should begin with "Convert" section from the menu on the right.
Since you are a newbie, like me, we should begin with reading the beginner's articles, as well. -
well ok but i have the avi file on cd and want to convert it to a vcd but the file is split into two parts is there a way to make it all one file thanx.
to join files: "How to - edit"
to convert files: "How to - convert"
to author/burn a VCD/SVCD/DVD: "How to - author"As Churchill famously predicted when Chamberlain returned from Munich proclaiming peace in his time: "You were given the choice between war and dishonor. You chose dishonor, and you will have war."
AVI to VCD
By Slip Kid in forum Newbie / General discussionsReplies: 4Last Post: 24th May 2009, 01:40 -
avi to vcd
By cornick in forum Video ConversionReplies: 4Last Post: 11th Aug 2008, 21:12 -
AVI to VCD
By northy44 in forum Authoring (VCD/SVCD)Replies: 4Last Post: 6th Dec 2007, 07:27 -
I have converted avi to vcd and svcd im looking to convert avi to dvd
By dbztoolkit in forum Newbie / General discussionsReplies: 1Last Post: 11th Jun 2007, 13:14 -
Convert NTSC AVI, DVD, (S)VCD to PAL DVD, (S)VCD
By scratchman in forum User guidesReplies: 14Last Post: 4th Jun 2007, 02:36
