im really new to this whole thing but i hope somone will take a bit of time to give me a hand.
i downloaded a video clip, used virtualDub to extract the .wav.
i then used TMPGEnc to convert the file into the correct VCD format,
i then burned it with nero as a VCD.
i had no problems.
upon inserting it into my standalone DVD player i had very nice Video byt no audio. i read the forums and downloaded GoldWave,this file DOES have audio according to GoldWave.
this has worked for me in the past,using the same steps so i know im doing it right.
also the videos have audio when i play then in a media player,as well i am running WindowsXP home edition,if it matters.
Thank you
Results 1 to 13 of 13
Can you hear the audio when you play it with Gold Wave? Just trying to make sure it is your file and not your program or hardware.
Hello. -
If you load the AVI as it is into TMPGEnc then select Setting > Audio > Use audio edit > Setting > Play
Can you hear it ?
It may help to install the Nimo codec pack, just incase you have an audio codec problem. -
well
donīt forget that VCD only accepts one audio track at mpg-1 layerII 224kbps stereo
2man -
I di as you said,loaded it into TMPEnc as it was, Setting.Audio>use audio edit>setting>Play. and yes it did play the audio.what now?
ok i also have this info for you guys, the files audio is: 44KHz, 224kbps, layerII, thanks guys for the help in advance.
how did you extract the wav in vdub?
did you just load the file and then save wav?
also
what format was the file that you loaded into vdub to extract the wav? -
Well that sounds correct, and it plays ok in TMPGEnc, so I guess there is nothing wrong with your save.Originally Posted by miscreant
Did you "Load" and load a VCD template ? This makes all the settings for you.
Then;
Browse > Video > AVI
Browse > Audio > WAV
START
Stop after a min or so, and test output -
CryptKeeper, yes thats how i extracted the audio in Vdub.as well i think it was AVI,but it coulda been Mpeg,i erased the originals because i though this would work so i cannot check.
KingJohn: I didnt use a template but i did use the page "www.vcdhelp.com/tmpgenc.htm" as i have done before, but this time it didnt work correctly.thanks again -
by chance did you forget to load the audio into the Audio source section of tmpgenc before encoding?
well as my experience tell me
if you have audio and no picture maybe you frame size isnīt 352*240(ntsc) or 352*288(pal) for vcd standards more your bitrate isnīt 1150 kbps CBR
you must verify all the video settings, if ok must burn with another program like CDRDAO (TRY VCDEASY)
2man
How to make audio / video business card and website audio/videos clips
By tmh in forum Newbie / General discussionsReplies: 6Last Post: 4th May 2011, 12:25 -
ASF2VC1 & transcode the audio WMA to AC3, then mux video VC-1 and audio
By tigerb in forum Newbie / General discussionsReplies: 0Last Post: 9th Jan 2010, 09:02 -
How to combine video with audio file and replace audio with video files ?
By designbuyers in forum Newbie / General discussionsReplies: 2Last Post: 8th Feb 2009, 12:12 -
Syncing spearate audio/video: Better to stretch/shrink video than audio?
By stantheman1976 in forum EditingReplies: 15Last Post: 16th Jan 2008, 05:14 -
Converting an AVI video with AC3 audio to an AVI video with MP3 audio
By rijulHKG in forum AudioReplies: 1Last Post: 15th Jul 2007, 01:23
