I serched threw this forum and found a lot of people having trouble with VirtualDub and WinXP. Basically the fact that any operating system after Win98 doesn't support VFW. Not nessasarly doent support it but doesnt have the required codecs for VirtualDub. I noticed a lot of questions about this with a whole lot of suggestions but no answers. I was looking for an answer myself. While researching this problem in this forum I came to understand that basiclly a VFW codec is needed and I found that the best codec avalible is a codec out of a $1,100 program wich makes it a unreallistic sullution, so I thought. Guess what I found. No not warez. Even better.
First let me tell you the codec comes out of a program by Pinnacle. So I thought I would go to the web page and hopefully find a link to a codec or possibly a update to the program with the codec in it. Well I went to the support products and found DV500. Hit the link and was then able to D/L the entire program.Sweet.
Gets even better. Then I went back and hit the Pro-One link and was able to D/L the new Pro-One beta v 2.0, and the Pro-One v 1.5. Guess what, You can D/L all their software. Including their DVD software. I looked at the checkout to see the Value of Pro-one, it's $1,100. No S____. Pinnacle is the richous deal. I felt as though I needed to share this with you all cause I know I would appreciate it if you shared this with me.
I do hope all you out there having trouble with VirtualDub find this before they break the link. I do suggest if you have good capture software to only download the DV500 as this is all you need to get the VFW codec to get VirtualDob to work.
Man what a find!! I hope you all are as excited about this as I am.
Anyhow, Good luck rippin those movies or producing those films. I am going now to play with my new SoftwarePeace out.
By the way, how about replying to this thread if it has helped you out, or if you where able to D/L software from Pinnacle, or if they broke the link so others won't waist their time.
Either way, please reply as I have spent the time to tell you about it.
Thanks a lot,
Doc
Results 1 to 11 of 11
Wow... great find. Thanks a whole lot for finding this... My ATI capture card doesn't like anything other than VFW, even with the latest WDM drivers. This should really help out when I try to bring my vids to VCD... Thanks again.
Hey dj_doc no matter what I DL from pinnacle its tell me I need the full verison which is $699.00 for the DV500 I can't seem to get my virutaldub to work it keeps tells me for the VFW codec can you help me out.......which is the one I should DL the free one..........thx
Hey I found the (VFW) codec so if your having problems with VirtualDub just go to the link I posted. DL that small file install it and should take care of your problem.
http://www.etymonix.com/products/VideoCodec/VideoCodec.htm -
Questions:
Since it is labeled upgrades, don't you need a prior version installed ?
or
are they demo's ?
What happened after you attempted an installation? Did you get errors, or did it fully install a working app. ? -
I installed the Pro-One with no problem. I also found that on the order page you can download a trial of Studio DV 7. Then get a crack. I am using the $1,100 Pro-One off of the D/L with no previous version. One of the plugins would not install off of the 2.0 beta version so I also D/Led the 1.5 CD image (About 200+Mb) and only installed the one plugin that would not install.
I do have Adobe Premire 6.0 installed. I don't know is this is nessasary or not for the install to work. I know it works with the program. -
Great work!!!
I'm sure you didn't mean a crack but a workaround. None-the-less it's a freebie from the Pinnacle people and fully legal.
Now if I could only figure a workaround for CCE Logo, nothing seems to work on this issue. -
Right now, I'm installing ProOne v1.5, without any previous versions. I plan to install Premiere later on, just to make sure that my system will work with this.... Once again, great find.
Pro-One is not a software-only product. It comes with a hardware for encoding and real-time video processing. Same as DV500.
LastQuark
TRV900/DV500/CCE/Impression DVD
Premiere/Avisynth/Ricoh 5125A/
DVD2SVCD/RecordNow Max -
Did somebody succeed to install and run Alpha Magic or Spice Master Premiere plug-in? It is contained in ProOne and 500 software.
VirtualDub being stupid (VFW codec...)
By Katsu-kohai in forum Video ConversionReplies: 20Last Post: 13th Jun 2017, 12:53 -
VirtualDub x64 with ffdshow vfw x64 no H264
By SandyB in forum Newbie / General discussionsReplies: 8Last Post: 10th Aug 2009, 17:45 -
Error with Xvid4PSP when converting MKV to AVI (VirtualDub Error)
By Peter25 in forum Newbie / General discussionsReplies: 1Last Post: 9th Apr 2009, 18:10 -
Problem with vdubmod with VFW error
By kagome in forum Video ConversionReplies: 2Last Post: 27th Oct 2008, 17:31 -
System.UnauthorizedAccessException error after WinXP SP3 install
By scoop46 in forum SVCD2DVD & VOB2MPGReplies: 10Last Post: 20th Oct 2008, 09:03
