I like the idea of making CVD resolution files for CDR now & no conversion to DVD when I get a DVD-R. Here are my trials & I'd appreciate feedback.
I have downloaded the CVD file from vhelp's site. His clip is basically the TMPGenc SVCD template with the following changes:
CQ mn600/mx1850 bitrate / 352x480 / 160 audio 48k / vbv:112
I have converted the Episode 2 high quality trailer to CVD with the following settings:
VBR 1600 min/2520 ave/2520 max 352x480 NTSC Audio 48k 224kbs
I had tried 384 kbs audio but was getting some skipping in one player - more below.
Burned with Nero, SVCD template, turn off compliant CD
I tried it in our 3 players with following results:
APEX 1500: played everything perfectly (no surprise)
Audiovox 1680 portable (DVD/SVCD/VCD/CVD/MP3/CD): good, audio skips a bit
Philips 711: Won't play any of it
Since the Philips is European & wasn't a CVD member this isn't surprising.
Questions (vhelp, SatStorm, & all):
1) Is there other settings to make the CVD video work in non-asian players with CD media?
2) What are the best settings - there is no TMPGenc template on the site - I am not a newbie & believe I have everything right but am unsure about the audio bitrate that may be best. Clues?
Can we lobby Ahead & TMPGenc.net to add CVD support/templates to their products?
Thanks all. If I can get things settled down I'll attempt to add CVD goodies to my website for others. The Kitty
Panasonic DMR-ES45VS, keep those discs a burnin'
The CVD thing, is basicly for the Video part (the m2v from the mpeg 2).
Something no one seems to follow:
First, test if your standalone supports 48Khz audio on CD media.
If not, then do typical CVDs
That means 352 X 576/480 with 44100Khz Audio!
Many problems are because of this: 48000khz ain't a standard for any CD based format! Some players handle it, but not all!
So, try again, with TRUE CVD audio specifications! -
Thanks SatStorm - the 44.1 KHz audio does allow it to play on the Philips 711 as well as the less tolerant players.
I am still having an audio problem. At 224kbs the audio hesitates every now & then. I lowered it to 160kbs which helps a bit and if I lower the VBR to 1200/2400/2520 it only jumps a bit but I am starting to sacrifice video quality for audio - is there another way to get the audio to decode smoothly? A setting I am missing?
Thanks, Da KittyPanasonic DMR-ES45VS, keep those discs a burnin' -
Hmmmm......
Try an imager.... VCD imager for example.
In theory, a CVD with 1200min/2300average and 2520max gonna produce SVCD quality.
There are some reports that if you low the max a bit (let say 2480) helps for such problems like yours
Anyway with philips' standalones, you must be really lucky in anything....
DVD & BluRay Menu + Chapter Creation Programs ?
By VideoFanatic in forum Authoring (DVD)Replies: 4Last Post: 2nd Oct 2011, 23:06 -
Great Article On Current BD Authoring Solutions & Future Mac Authoring
By videopoo in forum Authoring (Blu-ray)Replies: 1Last Post: 12th Dec 2008, 18:04 -
Microsoft trials XP on XO laptop
By JohnnyMalaria in forum ComputerReplies: 1Last Post: 10th Dec 2007, 01:21 -
Joining M2V & AC3 files for DVD burning, Subtitle creation sub position
By blue2 in forum Authoring (DVD)Replies: 15Last Post: 29th May 2007, 09:56 -
DVD Authoring: Menu Creation, Encoding, etc
By kerpal in forum Authoring (DVD)Replies: 7Last Post: 20th May 2007, 19:27
