Well, ok, here it goes:
Im new at this and i just learned how to make VCDs. I heard that SVCDS have better quality so i read the HOW-TO in this site in how to convert AVI to SVCD. So I read all the instructions and loaded the SVCD template and adjustded the bitrate and everything else, I did a preview and It looked great, and then i tried to do a sample, I started Encoding and stopped it after a few seconds. Then I opened up the output file with a few seconds encoded but then it says that the format isnt valid and that i dont have the codec. This does not happen when i do a sample for VCD only when its a sample for SVCD. Is there a specific codec i need for SVCD or did i do something wrong in the settings? (im using TMPGenc by the way)
Mpeg 2 streams are not natively supported by windows. You need to grab the codec or install your dvd software, if you have a dvd drive. I believe this is what you're looking for. http://www.mpeg.org/MPEG/MSSG/#source The.zip file contains the windows version. I haven't tried ot though. My dvd software handles .mp2 files for me.
I hope this helps,
FUGOFF
Encoding .Avi to Svcd?
By mrjust in forum Newbie / General discussionsReplies: 4Last Post: 16th Jan 2011, 13:40 -
Svcd Burning Problem with Nero 7
By Soixante in forum Authoring (VCD/SVCD)Replies: 4Last Post: 3rd Nov 2010, 11:59 -
Problems Converting AVI to SVCD
By wiseguy109 in forum Video ConversionReplies: 3Last Post: 6th Oct 2007, 14:17 -
avi to vcd/svcd
By neynme in forum DVD RippingReplies: 7Last Post: 26th Aug 2007, 20:25 -
I have converted avi to vcd and svcd im looking to convert avi to dvd
By dbztoolkit in forum Newbie / General discussionsReplies: 1Last Post: 11th Jun 2007, 12:14
