When I burned a VCD using Cdrwin 5.01, it created a new drive labeled 'image simulation' and renamed my other drives. I have renamed my drives back to the way they were, but I can't delete the new drive. Can anyone help me out?
If nothing else, I can always serve as a bad example
I had the same exact problem - "DRIVE F:"
i just got rid of cdrwin and the drive went away."With great power comes great responsibility"
WHO AM I? - I'm SPIDERMAN-(for real) -
Yeah, I figured out what happened after I deleted cdrwin and then re-installed it using the custom installation- there's an option to install a 'virtual cdrom'; why anyone would want to is beyond me, but I clicked that off and now cdrwin works fine ^-^
If nothing else, I can always serve as a bad example -
Perhaps the virtual drive would allow you to "run" your disk images, so that you can discover any problems before you actually burn the image to recordable media?
As Churchill famously predicted when Chamberlain returned from Munich proclaiming peace in his time: "You were given the choice between war and dishonor. You chose dishonor, and you will have war." -
I use Daemon tools to load the bin/cue that vcdeasy creates and view them with powerdvd before I burn with CDrwin. Typically if the mpeg that tmpeg creates is in synch and plays normally than the bin will be ok too..but its always nice to know for sure what you're getting before committing it to disc.
Its a nice program to use to install programs you run across in bin/cue format if you dont want to burn them to disc first as well.
Removed Esata drive and replaced with another drive. New drive is now unus
By cal_tony in forum ComputerReplies: 6Last Post: 7th Feb 2012, 15:17 -
cd drive not readind disc created many years ago?
By mikehende in forum AudioReplies: 18Last Post: 23rd Nov 2011, 17:47 -
Adobe Premiere created 0k files and I cannot delete them (SOLVED)
By mazinz in forum ComputerReplies: 5Last Post: 16th Apr 2010, 23:29 -
Question how to delete files that won't delete
By jimdagys in forum ComputerReplies: 18Last Post: 9th Sep 2009, 14:09 -
Can not delete CD drive from computer
By mysts in forum ComputerReplies: 11Last Post: 1st Aug 2007, 13:36
