Hi,
I 've tried to encode an AVI source file originating from DV (PAL 720x576) to SVCD (480x576) with TMpgEnc, then to XSVCD, that is, only modifying the size to 720x576 in the settings window.
Result: I can't see any quality difference, and moreover, the XSVCD mpg file is ... 5 % smaller than the SVCD mpg file !!!
Does someone know about this and what I am supposed to do to get a better quality with XSVCD ?
Thanks.
Changing the resolution has minimal effect on the filesize.
To get better quality over an SVCD (and a bigger filesize!) you need to encode at higher bitrates than a standard SVCD. This will howver make your video incompatible with some DVD players.
Encode little samples and test on your player.
is it possible to feel the difference?
By FaisalKhan in forum Newbie / General discussionsReplies: 1Last Post: 2nd Jan 2011, 06:17 -
What is the difference between these two HP laptops?
By jyeh74 in forum ComputerReplies: 5Last Post: 14th Mar 2010, 17:35 -
Difference DV capture?
By Abas-Avara in forum Newbie / General discussionsReplies: 6Last Post: 28th Sep 2009, 15:17 -
What's the difference between these two products?
By Waterkips in forum Capturing and VCRReplies: 1Last Post: 21st Apr 2008, 01:40 -
Can YOU Tell the Difference ?
By Seeker47 in forum DVB / IPTVReplies: 14Last Post: 19th Nov 2007, 13:59
