Hello,
While I was exporting a long project with bbMPEG for Adobe premiere toward a Mpeg1 file for VCD , my PC crashed (electrical failure in the all area).
It was during the multiplexing phase meaning (if I have understood anything) that I had already created both the video file (m1v) and the sound file(mp2) (which respectively look and sound fine).
Is there a way to create the mpeg1 file without having to go through the all export from adobe? If yes, how do I do that?
Pierre
multiplex, use tmpgenc found in the tools section. select your video type (mpeg) select the video and audio source and then choose 'run' and that sould do it hella lot faster then primiere!
...and after that, de-multiplex with TMPGEnc, and re-multiplex the whole new streams with bbMPEG again. No, really, do it...
TMPGEnc has a broken multiplexer, it doesn't keep your movie quite as well in synch.
You can still use the de-multiplexer, the merger, etc, but make sure to use bbMPEG to multiplex the final product. Trust me.
(famous last words)
Extract .m2v and .mp2 files
By geohei in forum Authoring (DVD)Replies: 3Last Post: 15th Sep 2010, 13:42 -
Possible to transfer subtitles from MKV HD file to converted MpegII file?
By peggypwr1 in forum Newbie / General discussionsReplies: 4Last Post: 18th Jan 2009, 10:58 -
VCD MPG1 file to CD Question
By Excelsior123 in forum Authoring (VCD/SVCD)Replies: 21Last Post: 22nd May 2008, 20:14 -
Convert mp2 file in TMPGenc
By sdlehman in forum Video ConversionReplies: 1Last Post: 17th Mar 2008, 17:53 -
Minimum MPG1 file size?
By Choppa in forum Authoring (VCD/SVCD)Replies: 17Last Post: 18th Jun 2007, 00:04
