When I put my own VCD (created with NERO 5.5, CD-Recorder LITE-ON LSR32123S on KODAK CD-R Ultima 80) in the DVD player DVP315E this one says me that the disk is not readable.
The DVD-ROM of my PC reads the VCD without any problem.
May the CD-R KODAK Ultima 80 be unsuitable?
There is any type of setting that I have to do before recording ?
I looked up your player in the DVD Player database at right. Three of the eight reports were able to play a VCD. The manufacturer says that your player will NOT play CD-Rs. If you refuse to give up after this, I suggest you contact one of your fellow owners, using the PM function here and see if they are willing to help you. Good luck!
Hello. -
is this a sony player? if so try datasafe media discs, the old type not the new silver ones or try princo RW
these are the only discs I know of so far that work in mine (dvp515) so yours might be the same
Don't read DVD-RW disc
By Phoenix 37 in forum DVD & Blu-ray WritersReplies: 7Last Post: 28th Jun 2011, 12:33 -
DVD Hardware Guide: mp3 wma crossed out. Means unit don't read that?
By TomBrooklyn in forum Newbie / General discussionsReplies: 0Last Post: 4th Aug 2010, 07:26 -
Why don't drives read HD-DVD anymore?
By Sephiroth666 in forum Blu-ray RippingReplies: 40Last Post: 10th Dec 2009, 18:48 -
Subs work on PC/VLC Player...but don't show up on dvd player
By bgart13 in forum SubtitleReplies: 9Last Post: 22nd Aug 2009, 19:06 -
Backup DVD can't be read normally, menus don't work
By chtit_draco in forum DVD RippingReplies: 7Last Post: 18th Apr 2009, 10:30
