Could anybody tell me normally how long to convert 2 hours dvd format to MPEG in PC ? I try this before by software dvd2mpeg and it need almost 12 hours to complete it.
Do you have any suggestion to reduce the useable times and what software is the better to instead the dvd2mpeg software ????
Well It depends on what program you are using and the speed of you cpu. This also includes the amount of memory. The progams I use are tmpgnc, dvd movie factory, spruce up. The tmpgnc takes any where from 6- 8 hours to decode to dvd (mpeg2 Format). The other programs are used to make menus and convert it to true dvd format and burning them to a dvd-r . I hope this helps you out and if you need more info then email and i will gladly reply peace :P
Splitting long (hours) MP3 files by sound breaks
By lostinlodos in forum AudioReplies: 3Last Post: 19th Mar 2009, 22:37 -
What's the better way to record/convert mpeg and mp4 format?
By Mark WR in forum Video ConversionReplies: 0Last Post: 11th Aug 2008, 18:21 -
Convert MKV to MPEG-2...format questions, etc.
By pcombs in forum Video ConversionReplies: 1Last Post: 20th Jul 2008, 17:58 -
Fitting Two Hours of Mpeg to DVD - How?
By markannab in forum Authoring (DVD)Replies: 12Last Post: 8th Nov 2007, 00:10 -
Convert videos from .VOB format to MPEG?
By hawkeyed76 in forum MacReplies: 5Last Post: 10th Sep 2007, 02:10
