My Cd-RW unit is supposed to support 900 meg Cd's. But when I insert them into Nero, nero claims they havee only 703 megs, any idea how to sovle that?
There is no way to read the capacity from 90 and 99 min CD-R just because it's impossible to store this information on the CD-Rs. So CD writing software will give wrong information about the capacity of such CDs. But you should be able to use the whole capacity. Low writing speed should be used.
Some programs have a list of 90/99 min CD-R brands and their capacity and so they tell the capacity from the values of this list. AFAIK Feurio (www.feurio.de), a writing software specialised on audio CDs is such a program.
M!chael -
Does that mean I won't be able to burn SVCD's on them? Not beng able to use the extra spacE?
If you CD-RW drive supports 99 min CD-Rs you can use all the space with Nero. You need to enable the 'overburn' option in the 'Expert Features' tab.
I've made several 90 min. VCDs with Nero in order to fit movies on one CD instead of spreading them over 2 CDs. Works fine.
M!chael
change aspect ratio in mp4box saves a few megs?
By silverwolf0 in forum Newbie / General discussionsReplies: 1Last Post: 10th Aug 2011, 04:19 -
Compressing 1.32 GB iPhone 4 video to 900-950 MB
By kingmustard123 in forum EditingReplies: 4Last Post: 19th Oct 2010, 11:53 -
2:30 minute video is 564 megs in size after rendering in Vegas
By Great Googly Moogly in forum Newbie / General discussionsReplies: 2Last Post: 30th Mar 2010, 02:19 -
How do I reduce the MEGS on my video from my digital camera?
By prettycat in forum Newbie / General discussionsReplies: 9Last Post: 10th Sep 2007, 22:15 -
Cards and 1400:900 resolution
By 123fish123 in forum Newbie / General discussionsReplies: 9Last Post: 24th May 2007, 18:23
