I`ve been given a dvdrip vcd of mission to mars.It plays fine on my pc but when played on my dvd the picture is ghosted buy about 10mm (overlapped).
all my other vcds play fine on my dvd.
i was told mission to mars was originally a dreamcast vcd but he had converted it?
i know nothing about tempgeng but......when i load it up the info at the bottom of the screen reads like this:-
MPEG 1 352 x 192 25 fps CBR 1150Kbps Layer 2 44100Hz 192bps.
is there any way to fix the vcd to play on my dvd player.
Note: i only have a amd 350Mhz with 64Mb of ram and 3Gig free space.
any help greatly appreciated!
Your Setting:
VCD Settings:
MPEG 1 352 x 288 25 fps CBR 1150kbps Layer 2 44100Hz 224bps
as you can see, there are 2 diffrences that might cause you the troubles you are having, most notibly would be the resolutions, yours is way below PAL VCD, and that what is causing you the overlapping on your DVD Player, if you want it fixed, you will need to re-encode the movie into the correct VCD PAL standard.
Email me for faster replies!
Best Regards,
Sefy Levy,
Certified Computer Technician. -
Thanks sefy,for your help m8,did what you said re-encoded the mpeg loaded up the pal vcd template waited 7hours!.
used vcdimager gui and burned with cdrwin,popped it into vcd and success!! all works fine.
just hope its a good movie LoL
ta stuart -
Glad to hear my suggestions have worked, as for the movie, well, I can't do everything now can I
Keep up the good work and good luck with your next masterpiece!
Best Regards,
Sefy Levy,
Combining synched sound with video - total absolute newbie
By Povster in forum Newbie / General discussionsReplies: 2Last Post: 24th Mar 2011, 16:37 -
Total newbie needs help urgently (AVDHC -> DVD, with complications)!
By sebkni in forum Newbie / General discussionsReplies: 0Last Post: 17th May 2010, 13:11 -
Total Newbie- Need help Premiere Elements 4- Two cameras Rendering
By VitalExpressions in forum Newbie / General discussionsReplies: 0Last Post: 16th Feb 2010, 21:53 -
total newbie dvd converting burning
By mujin in forum Newbie / General discussionsReplies: 6Last Post: 29th Jan 2009, 11:28 -
Advice for a total Newbie
By Lawman1965 in forum Newbie / General discussionsReplies: 1Last Post: 25th May 2008, 12:24
