I cant figure it out. I keep freezing in the same place trying to encode jurassic parkII. I used divfix to reindex, I checked for errors 2x. I checked for bad video frames with virtualDub 1.4. I even ruled out CPU overheat, I moved to just that spot in the movie and encoded it. It froze on the exact frame 2 minutes into encoding process. I give up. What program can you use that will actually identify a bad frame and fix the thing?
War
just use virtual dub to cut out the bad frames
there is also a new version of tmpgenc out, version 2.57. you might give it a shot!
DVD Video Freezing after conversion from AVI
By Beeblebrux in forum ffmpegX general discussionReplies: 9Last Post: 6th Mar 2010, 21:04 -
Tmpgenc keeps freezing
By WinSpecToR in forum Video ConversionReplies: 6Last Post: 12th May 2008, 01:08 -
Slight freezing about 1 mins into re-encoded DVD (from AVI)?!?!
By josam in forum ffmpegX general discussionReplies: 3Last Post: 11th Dec 2007, 03:18 -
TMPGENC DVDAuthor 3 freezing up during output process
By CodySave in forum Authoring (DVD)Replies: 1Last Post: 21st Jul 2007, 12:57 -
File size problem with TMPGEnc [.avi to .mpg conversion]
By Timex in forum Video ConversionReplies: 7Last Post: 26th Jun 2007, 22:50
