Hi, I was wondering if there is a way to make a svcd work like a dvd with regards to being able to stop a movie anytime I want and when I hit the play button it will play right where I left off. I did put in chapters.
DVD- apex 1500
Tools - tmpgenc- vcd easy![]()
Thanks for the help.
Results 1 to 14 of 14
In vcd easy under the options menu make sure use playback control is checked then you should be able to pause or ff and rw
I did that and it will do as you said but I thought DVD players would be able to stop anywhere ( not pause) and you could start where you left off. I guess it also would be like a VHS tape.
once you press stop thats it you have to start on the closest chapter and ff . that goes for com. dvd's as well .
I'm not sure about Apex players but I have a Logix 3000 and if I power the machine off during playback of a SVCD it will automatically start from the same point when I power it on again.
I have a apex 1500 ( the cheap one) and with a real dvd video I can press the stop button and when I press play again it is exactly where I left off. With my home made svcd's or vcd's I can't do that . I have to go to the nearests chapter.
I am still puzzled.
it is a player feture, not all DVD players have this feature.
ChRaN :-) -
I thought it was possibly the way I made svcd's? I use the tmpgenc and vcd easy
1) Encode to mpg2( From avi)
2) Put in chapters
3) Burn to disc
My dvd's and vcd's both play from where they were stopped on my pioneer 636d. It also has a 5 disc memory. So you can stop a disc, eject it, play another disc, put the first disc back in and it will resume from where it left off.
Craig -
The feature is called Resume and because of the licence
cost - not all DVD players support this. Some Asian players included it
but did not pay for the privilage. -
It will " resume" with a purchased DVD but not with my homemade SVCD's.
I just thought I was making the SVCD with a step missing.
When you create your vcd you must either turn off PBC or use a play list for the chapters instead of a selection.
see vitualis's post here
http://forum.vcdhelp.com/viewtopic.php?t=95277&highlight=resume+pbc
It didn't help me. My VCDs still don't resume. But I know it works for a lot of people.
jbirdg -
jbirdg
You rock, I finally understand you either get chapters or the resume funtion not both.
First Stand Alone RM/RMVB DVD Player
By sushix in forum DVD & Blu-ray PlayersReplies: 13Last Post: 7th Jun 2009, 02:42 -
Stand-Alone DVD Player recommendation
By -mm- in forum DVD & Blu-ray PlayersReplies: 24Last Post: 2nd May 2008, 13:13 -
SVCD converted movie with choppy playback at the end on stand-alone player
By supernano in forum Video ConversionReplies: 0Last Post: 27th Oct 2007, 11:10 -
Adding subtitle to a movie and use it only in a STAND-ALONE DVD player ?
By bradford in forum Newbie / General discussionsReplies: 1Last Post: 27th Oct 2007, 02:59 -
DVD player stopped working
By ishotlove in forum DVD & Blu-ray PlayersReplies: 7Last Post: 31st Jul 2007, 16:44
