Hi there, I'm trying to capture some old VHS footage using my Brooktree Capture Card with Virtual Dub. I manage to get the video and audio working together but the picture sucks!!! I seem to be getting a wavy pattern over the video, a bit like watching another tv on tv.
Can anyone offer some advice?
Thanks in advance!!
chrome ;0)
you mean like seeing a computer screen on tv?
where it has the refresh rate showing? -
Yep, kind of. Someone told me to look at purchasing some Ferrite Beads to wrap around the capture cables, it's like a humming on the picture.
If your in the US, look up the beads in RadioShack and it will explain a lot clearer than I ever could. :0)
chrome ;0) -
is there anything close to your cables that could create such an interference?
I have a few capture cards I use, and have seen the same problem you are seeing. I got rid of the problem by unplugging some of the many AC adapters I have when trying to capture video. You should also look into some heavy shielded audio/video cables. That should also help.
What capture card do you have exactly?
Capture card for Laserdisc and VHS - Good card/quality
By darkbluesky in forum Capturing and VCRReplies: 85Last Post: 21st Mar 2012, 13:27 -
Which $150 or under capture card for VHS/S-VHS -> computer?
By HDClown in forum Capturing and VCRReplies: 25Last Post: 16th Apr 2010, 23:16 -
VHS tape capture "flickering" - Intensity Pro Capture Card
By mofaster in forum Capturing and VCRReplies: 2Last Post: 31st May 2009, 13:56 -
Best S-VHS To best Capture card
By samturner01 in forum Authoring (DVD)Replies: 7Last Post: 15th Feb 2008, 19:00 -
suggestion for vhs capture card
By abbymat in forum Capturing and VCRReplies: 8Last Post: 28th Jul 2007, 01:57
