When I encode an avi file from my camcorder into svcd the picture gets all tall and skinny. It says svcd is 480x480, so does that mean it'll compress the picture to that size thus causing it to look tall and skinny? Is there any way around this. I want to make a svcd but with the correct aspect ratio. Any help would be greatly appreciated.![]()
I am using TMPGEnc. And I tried settint the source to both 1:1 vga and 16:9 and still the picture looks tall and skinny. I want the 2 sides to get cut off so it looks right but it seems like it only compresses it to make it 480x480. I've also done it witha divx movie with the same incorrect aspect ratio result. What am I doing wrong?
I don't think you're doing anything wrong.
Yes, the standard SVCD size is 480 x 480. so if you play back the video file in your media player, it will look skinny and stretched. if you change your media player to fullscreen mode, or play the file in your DVD player, it will fill the whole screen and look correct. You don't have anything to worry about
MarkSwim with me
And we'll escape
All the trouble
Of the present age
Finally free
Help with HF200 (24p and 30p question) technical question
By Coldbricks in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 1Last Post: 15th Jun 2010, 13:24 -
Mod16 question and DAR question...
By alcOre in forum Newbie / General discussionsReplies: 5Last Post: 31st Oct 2008, 15:18 -
Age old question of VHS to DVD question...I still don't get it.
By saywhat? in forum Newbie / General discussionsReplies: 4Last Post: 10th Oct 2008, 22:43 -
Help with PAL SVCD to NTSC SVCD
By silentmonolith in forum Newbie / General discussionsReplies: 4Last Post: 6th Jul 2007, 06:18 -
Patching SVCD to DVD question
By zanos in forum Authoring (DVD)Replies: 22Last Post: 29th Jun 2007, 09:17
