I have an MPEG-1 file that I want to use that is 457MB. With just the file, when I update the project size, it says 1.36 GB and won't let me make it any smaller using the audio and video settings.
But I do want more than just the movie on the VCD, I wanted to have menus, chapter selections, and backround music but there is no way I can do this if the movie itself won't fit.
Does anyone know how or why the file expanded from 457MB to 1.36GB?
I haven't a clue
I'm trying DVDIT myself and it won't let me add other mpegs
because the link to an mpeg is broken
I deleted the file
and now it just won't let me add any others to the media section of dvdit -
hi,
had the same sort of problem with dvit myself...
try selecting under project settings : set project size ; 4.7gb (dvdr)
then when you have finished adding your files, under build select : make dvd folder and save to your hdd... the file size should be smaller than dvdit said.
to be honest, if you are making vcd, have a look at vcd easy or roxio videopack 5.. i have had some great results with videopack on vcd, dvd and svcd
-moley -
It may have something to do with the audio, I use DVDiT but change my audio to bitrate 192/dual digital. To do this click on build, select audio and make the change, you should do this each time you do a build, if you don't DVDiT will force PCM which creates a bigger file.
Aloha
Bud
subtitles with DVDit 6 PRO
By jakewoodblues in forum Authoring (DVD)Replies: 2Last Post: 16th Apr 2010, 13:51 -
Replacement for DVDit Pro HD 6.3 Final
By GrampaD in forum Authoring (Blu-ray)Replies: 2Last Post: 11th Oct 2009, 11:04 -
Subtitle Sync Problems in DVDit Pro
By aquaorbis in forum SubtitleReplies: 0Last Post: 5th May 2009, 22:40 -
Has anyone used Sonic Scenarist or DVDit pro HD?
By jbandy1 in forum Authoring (Blu-ray)Replies: 16Last Post: 18th Feb 2009, 01:08 -
DVDit Pro HD and Sript error in activation
By arturjose in forum Authoring (DVD)Replies: 1Last Post: 19th Nov 2007, 00:51
