  1. I tried to mux an .mpg made with ffmpegX and an audio file in .mov format in MMT and it gives me an error saying that both file types are unrecogniseable. What do I need to change in order to get MMT to mux them?
    Nov 2001
    squeed
    What is MMT ? Where can I find it ?
  3. The .mpg made by ffmpegX is a system stream, so you should first use bbdemux to extract the .mpv elementary stream and use that one for re-muxing. The audio must be a .mp2 file and not a .mov audio. BTW what are you trying to do? There is maybe a simpler way to do it.
  4. As noted in previous posts, I've had problems getting audio to sync when converting directly from a VOB to MPEG-1. In order to solve the sync problem I first coverted to DivX, fixed the audio with DD, and then exported the audio track. Then I took the same VOB file and converted the video to MPEG-1. Then I wanted to mux the MPEG-1 file and audio track I exported in DD but MMT says both files are unrecogniseable.
