Just got a copy of LOTR on VCD. Burned the first disk from an ISO, fired her up in my Hiteker DVD player (plays other VCDs and SVCDs no problem). The VCD plays, but is not widescreen, is pushed over to the left side of the screen and flickers like crazy. Any ideas what the problem is? Certainly isn't a PAL/NTSC problem. Like I said, other VCDs and SVCDs play perfectly.
It isn't a problem with the VCD as others have played it perfectly.
what do you mean "Burned the first disk from an ISO" ?
Are you burning it like you're burning a data ?
What burning software are you using ?
did you make a copy of the LOTR ?
then you should use "copy mode"
Burning a vcd should be in "vcd mode"
Help burning and playing VCD
By NLO_Cliff in forum Authoring (VCD/SVCD)Replies: 12Last Post: 16th May 2011, 09:55 -
Cyberhome 300 problem after playing VCD discs...
By MrCairo in forum DVD & Blu-ray PlayersReplies: 2Last Post: 14th Mar 2011, 17:57 -
Burning DVD using ConvertXtoDVD - rating problem when playing?
By mistyfog in forum Newbie / General discussionsReplies: 1Last Post: 20th Jun 2009, 10:28 -
Problem burning data DVD using Nero 6 burning rom
By thebluekey_17 in forum Newbie / General discussionsReplies: 3Last Post: 19th Feb 2009, 13:14 -
converting, burning, and playing avi files
By unionman4077 in forum Video ConversionReplies: 1Last Post: 27th Feb 2008, 17:01
