Hi, I tried to convert .avi to xvcd by using TMPGEnc but it gave me an error when I pointed to the avi file for the video source. The error was: [movie name] can not open, or unsupported. However, when I try to load the audio source it works just fine. Can someone please tell me why is it doing this.
Thanks,
Hash2
<font size=-1>[ This Message was edited by: hash2 on 2001-08-08 11:27:19 ]</font>
The stream was encoded using an unsupported codec, like Windows Media8. Per M$'s request, developers have removed support for these files. You can try opening it with an older version of Virtualdub and re-encoding it to divx or something. When that's done you can use it in tmpeg. Maybe that will work for you,.
Good Luck
FUGOFF
Dazzle dvc100 w studio 12 does it capture AVI 1 or AVI 2 or DV-AVI
By st711 in forum Capturing and VCRReplies: 1Last Post: 10th Dec 2009, 18:30 -
avs (avi to avi) ends up out of sync ... winavi output file too big
By mandy in forum Video ConversionReplies: 1Last Post: 21st Aug 2009, 06:56 -
ffmpeg choppy audio from large avi but not small avi source file
By cybertheque in forum Capturing and VCRReplies: 9Last Post: 13th Oct 2008, 16:38 -
ffmegX v0.09w and converting avi videos into avi.ff.avi videos
By paddymick in forum ffmpegX general discussionReplies: 2Last Post: 3rd Nov 2007, 00:10 -
How To Split Single DV AVI file into Multiple DV AVI files using Time Stamp
By insysnet in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 2Last Post: 23rd Aug 2007, 13:49
