I am burning using Nero, and it says that streaming video won't work when i try to burn. What should I set the "rate control mode" at in the Configuration (under video). Any help would be appreciated!
Thanks,
Joel
oh, and nero says: "the following problems were found: stream encoding which is invalid for [super] VCD"
I am just burning a VCD by the way. -
In what format is your streaming video? Chances are it is not MPEG-1 for VCD compliant, so you'll have to re-encode it. Look in the site navigation menu on the left and read the section called CONVERT.
ffmpeg rate control
By diprotic in forum Video ConversionReplies: 2Last Post: 15th Oct 2011, 22:35 -
How to achieve the maximum bit rate in variable bit rate mode ?
By Sxn in forum Newbie / General discussionsReplies: 42Last Post: 3rd Dec 2009, 12:53 -
mpg file size smaller than expected, TMPGEnc 2.5 VBR 2-pass mode
By chipsndukes in forum Video ConversionReplies: 1Last Post: 22nd Dec 2008, 20:48 -
Selectable Output Control - MPAA's new control tactic
By akrako1 in forum Latest Video NewsReplies: 2Last Post: 7th Aug 2008, 21:05 -
Having issues with Clone Mode in Catalyst Control Center...
By Jaxel in forum ComputerReplies: 1Last Post: 25th Feb 2008, 05:08
