Hi I have a problem with Tmpeg when i merge my mpg files I hear a popping/click sound in the area where the merge was made. Is there a remedy for this?
Cliffv
TMPGEnc may add that if the end of the source has more pictures without sound, use split/merge on part 1 and remove a frame or so from the end, TMPGENC will automatically jump to the key frames.
Do the same with the beginning of part 2
This is not very good, but TMPGEnc cannot edit a frame at a time.
You could also go to the join, and delete the section with the beep -
If you have audio editing software that can handle a file that large, you could also demux the joined MPEG and just "silence" (not delete) the pop. Unless it's in a particularly noisy scene you can probably see it in the waveform.
Popping, clicks, dropouts when making cuts
By chef2 in forum EditingReplies: 7Last Post: 28th Apr 2012, 19:01 -
'Popping' speakers
By koberulz in forum Newbie / General discussionsReplies: 11Last Post: 11th Apr 2012, 15:58 -
Audio popping with long movie's
By md0234 in forum ffmpegX general discussionReplies: 0Last Post: 20th Oct 2007, 12:50 -
Help with popping & cracking sound from pc
By gyles in forum AudioReplies: 1Last Post: 12th Aug 2007, 13:54 -
How to figure out why during playback skipping, popping occurs
By CurtisMinBC in forum SVCD2DVD & VOB2MPGReplies: 9Last Post: 28th Jun 2007, 23:57
