I am trying to take my music video collection off VHS tapes and burn them with menus and the works onto DVD-R. I want to give this collection to at least 10 of my friends and they have different setups and different DVD players. I thought about doing CVD, but I heard it is only compatible with 1/3 to 1/2 of existing DVD players. THat's not very good for me. Should I just waste space by capturing at full D1 resolution at 720x480 and burning that? How much more compatible would that be? How many DVD players are compatible with DVD-Rs and what brand of DVD-R would you guys suggest? I'd appreciate any help with these questions! THANKS!
I think the information regarding CVD being compatible with only 1/3 to 1/2 of all DVD players is relevant only when those video specifications are being burned to CD media - a CVD is a CD format.
If you are working with DVD-R, you should have absolutely no problems with MPEG2 at CVD specifications (MPEG2 352x480/576, 48Khz audio) because it is allowed within the DVD specification. The only issue will be media compatibility - you should be able to get some feel for this by browsing the DVD Players Compatibility list to the left. -
Can anyone give me an idea of how compatible DVD-Rs are across the board? I'm thinking Philips or Apple DVD-R media. Can anyone give me some good prices on those in the $4 per disc range?
Kinneera, when you said that CVD is a CD format, did you mean that it's traditionally burned to a CD, but it's perfectly valid on DVD? Does it have the same compatibility as full D1 resolution? -
Exactly: if it's on a DVD, it's not a CVD - it's just a DVD at a lower quality specification. It should be just as compatible as CCIR-601 encoded DVDs.
DVD Lab Pro Menu Resolutions
By Anonymous344 in forum Authoring (DVD)Replies: 0Last Post: 6th Dec 2010, 18:11 -
Issues Authoring DVD with different resolutions
By Smack2k in forum Authoring (DVD)Replies: 3Last Post: 11th Nov 2009, 03:24 -
Help with choosing compression for DVD files
By BooBerry in forum DVD RippingReplies: 1Last Post: 16th Apr 2009, 11:47 -
Choosing 'best' size of AVI for DVD?
By terrypin in forum Video ConversionReplies: 8Last Post: 25th Jul 2008, 12:42 -
DVD screen capture resolutions???
By cabala420 in forum Newbie / General discussionsReplies: 4Last Post: 25th Apr 2008, 12:28
