I'm using DVD2AVI, and i notice there's several options for audio.
I noticed that on my SVCDs that the spoken audio is lower than the music audio on the DVD. Or maybe i'm just crazy and am hearing things.
Reguardless, here's my DVD2AVI settings for audio:
Track - Track 1
Channel Format - Auto Select
Dolby Digital - Decode
MPEG Audio - Demux
48->44.1 KHz - Off
Normalization - (checked)
Here's my DVD setup, i got my DVD player hooked into my TV, and the TV hooked into a stereo for louder sound. Are these settings good for just plain sound (meaning i don't use a reciever or special equipment for my DVD sound).
If a DVD is set to play at the best quality sound 5.1 Digital Sound (i think that's what it's called), will the sound be different on my regular setup than if i had the setting at Surround Sound?
Any help is appreciated! If you know somewhere that this question was already addressed, please link me.
Thanks!
Mojo
Hello pal,
First, the quality of sound is much better when played through an AV receiver with 4, or 5, or 6 high quality loudspeakers. This way you will get the surround effects. The overall quality of the sound depends first on the quality of the loudspeakers and to some extent on the quality of the amlifier or AV receiver. Anyhow, there is no surround effects with only 2 speakers, played from a stereo amplifier, or receiver.
On many movie DVDs, the music and effects level is at times louder than the dialogues. Compare this between your original DVD and encoded VCD/SVCD.
Take care -
Thanks for the tip!
I'll definately compare the originals to the SVCDs, i'm surprised i didn't think of that
Thanks!
Mojo
5.1 Audio Question
By Simmons in forum AudioReplies: 0Last Post: 22nd May 2011, 10:12 -
Correct AR(aspect ratio) on dvd2avi conversion (16:9 vs 1.85:1)
By Visual-Artist27 in forum DVD RippingReplies: 10Last Post: 20th Aug 2010, 00:11 -
question about demagnetizing audio head on VCR to improve audio
By jimdagys in forum Newbie / General discussionsReplies: 3Last Post: 29th Aug 2008, 17:47 -
How to frameserve (dvd2avi / VirtualDub / Avisynth / VFAPI)
By Truman in forum User guidesReplies: 32Last Post: 20th Nov 2007, 09:38 -
Audio question.
By cowboysroy31 in forum AudioReplies: 2Last Post: 5th Jul 2007, 12:44
