I have successfully captured 352x288 from VHS tape using VirtualDub via an AVER TV98 card. I get 25 fpm without dropping frames, and my overclocked 300/450 MHz Celeron does not even break a sweat. This is using Huffyuv as explained in http://www.vcdhelp.com/mjpeg.htm
Last night I attempted to capture an old tape, of poor quality. I could not get above 16 fpm, dropping 40% of frames. I though there was something wrong with my settings, but could not make it work.
However, when I tried a good quality tape, it worked perfectly! Can someone explain this, and tell me how to get the capture to work??
TIA
On bad sources you may need a time base corrector. I have a Sigma TBC
and it works very nicely.
Sharp VCR (or similar) S-VHS quality for best capture of my VHS tape?
By ruehl84 in forum Capturing and VCRReplies: 0Last Post: 19th Feb 2012, 16:52 -
Question about Bit Rate and Quality
By T375 in forum Newbie / General discussionsReplies: 4Last Post: 20th Sep 2010, 10:31 -
Bit Rate Vs Quality
By kashif71 in forum Video ConversionReplies: 20Last Post: 21st May 2010, 01:19 -
8mm tape source filmed twice
By Dieu in forum EditingReplies: 9Last Post: 17th Nov 2009, 20:14 -
Is higher bit rate = better quality??
By imdaman in forum DVD RippingReplies: 5Last Post: 13th Sep 2007, 08:37
