I have a bunch of mpegs that I'm ready to burn, and was curious how reliable vcds are.
FWIK, VCDs are burnt in mode 2 similar to red book audio. A lot of cd readers in the old days had difficulty 'extracting' audio. Drives are much better at extraction these days but its still not as trivial as just copying files from a cd.
I'm posting this cause a friend of mine burnt a lot of vcds and while they played fine on his dvd player, he couldn't properly extract the mpegs without errors. He blamed it on cheap media, but even with cheap media, I can be relatively sure that, with good care, I can copy those files again.
Has anyone had the above situation where they could play a vcd but no longer copy/extract it?
It's just after encoding all this stuff I'd hate to think I could never back it up again.
Does anyone actually burn it as a vcd and a normal disc to retain the 2nd level of error correction? I can't imagine doubling my discs.
So how reliable are your vcds? What's the oldest that you can still reliably copy?
Cheap media is always a problem, as is finger marks and scratches. Poor quality writers, may also contribute to disks not lasting.
Use good quality disks and don’t touch them and they last for ever.
Burning mixed/split mono VCDs
By ministry88 in forum Authoring (VCD/SVCD)Replies: 5Last Post: 21st Jul 2011, 12:04 -
DVD Decrypter: File Mode total size double that of ISO read mode
By dare2be in forum DVD RippingReplies: 7Last Post: 13th Feb 2011, 12:21 -
DVD-rip compared to VHS
By Digiface in forum MediaReplies: 7Last Post: 4th Aug 2008, 12:34 -
Advantages of ripping in File mode over ISO mode...
By hiimbored in forum DVD RippingReplies: 9Last Post: 5th Jun 2008, 15:27 -
DVDlab Compared with TDA
By loster in forum Authoring (DVD)Replies: 7Last Post: 30th Dec 2007, 19:34
