can some one tell me how i can convert a svcd mpeg file into a normal vcd mpeg file so i can burn it with nero as a vcd
Simple... Downgrade it using TMPGEnc.. Use a simple VCD template and your set.... If you need help with the program, the how to rip a DVD on this site should explain the program well enfough..
I can't get my tmpegencoder to use the mpg2 file as a source, so I have always had to split the video and audio with dvd2avi, and then encode to a vcd. Hey, it works!
tried to open file with tmpegenc but just says cannot open or unsupported any one have any ideas ?
VCD to DVD (not SVCD)
By noyou in forum SVCD2DVD & VOB2MPGReplies: 20Last Post: 19th May 2009, 17:56 -
How to make a VCD/SVCD with CD Audio (CDDA)
By Baldrick in forum User guidesReplies: 74Last Post: 24th Dec 2007, 19:37 -
Beeping on vcd/svcd
By mgdt in forum Newbie / General discussionsReplies: 5Last Post: 20th Dec 2007, 11:56 -
avi to vcd/svcd
By neynme in forum DVD RippingReplies: 7Last Post: 26th Aug 2007, 21:25 -
How to copy-protect a VCD/SVCD v2.0
By Sine29 in forum User guidesReplies: 23Last Post: 20th Jul 2007, 11:27
