I have a satellite signal I want to capture and so far I have been using the Navis-Pro realtime MPEG2 capture card.
Instead of taking the composite or s-video signal out and feeding it into a capture card, I figured it would be much better to just capture that digital signal to the hard drive directly. Then I would have the same MPEG2 data that the satellite gives (i.e. no loss).
Does this sound right? And if so, does anyone know of any product that can do this? Also, a capture scheduler (PVR) application would be good too.
P.S. I think I have seen PCI satellite receiver cards, but I'm not sure if they just play out to TV or actually save the file to disk
Results 1 to 1 of 1
No dvb-s signal from satellite and Asus My cinema es3-110 card
By mammo1789 in forum DVB / IPTVReplies: 4Last Post: 28th Dec 2011, 17:13 -
DVB-S/DVB-S2 Satellite Receiver with direct HD,SD/SDI output not HDMI
By rahemeen in forum DVB / IPTVReplies: 1Last Post: 19th May 2011, 05:38 -
Can I transfer my direct tv dvr movies to a hard drive?
By Vityaz in forum DVB / IPTVReplies: 11Last Post: 23rd Jun 2009, 16:54 -
Direct from DVR to computer hard drive?
By jdcrowley in forum DVD & Blu-ray RecordersReplies: 2Last Post: 29th Sep 2008, 21:08 -
Hard drive camcorder direct to DVD burner?
By h08 in forum DVD & Blu-ray WritersReplies: 7Last Post: 12th Oct 2007, 17:47
